vcSimFlowField
A Flow field allows you to transfer components.
Module: vcBehaviors
Parent: vcSimInterfaceField
ContainervcFlowRWGets or sets a vcFlow behavior in component used by the field.
PortIntegerRWGets or sets index of connector of Container that is used by field, thereby defining if field transfers components into or out of Container.
Synchronized with PortName.
PortNameStringRWGets or sets name of connector of Container that is used by field, thereby defining if field transfers components into or out of Container.
Synchronized with Port.
